[RESOLVED] Empty WUA repository
t.heroult
Registration: December 8, 2020 - 10:13 AM
December 10, 2025 - 11:40
Hello
, today my server is acting strangely!
The /var/www/waptwua directory is full with almost 300 files, but the console remains stubbornly empty, and when I try to install Windows updates, waptwua fails because it can't find the files to download.
How can I rebuild the update database?
Of course, I've rebooted the server, but that didn't change anything.
Thanks in advance for your help!
Consoles: Windows 10 & 11
Infrastructure: Windows
blemoigne
Registration: July 17, 2020 - 11:29
December 10, 2025 - 11:45
You should check the download history from the Windows Update tab in the WAPT console and perhaps also /var/log/wapttasks.log on the WAPT server.
Best regards,
Bertrand
t.heroult
December 10, 2025 - 12:01
Screenshot 2025-12-10 115727.png (37.2 KB) Viewed 11372 times
The history shows nothing abnormal.
As for wapttasks.log, it only contains INFO, no errors.
December 10, 2025 - 4:55 PM
We would need to check the database status with this SQL query to see:
SELECT * from WsusUpdates
Apparently there are cab downloads, so it looks more like a problem with a filter checked in the GUI.
t.heroult
December 11, 2025 - 11:08 AM
Hi.
So, I don't know what happened, but this morning it was back to normal.
I waited until at least one machine was properly updated, but it's all good now.
We can close this.
Thanks. :)
