[SOLVED] Problem with tis-anaconda3 folder not being empty
Mikael S
Registration: January 20, 2025 - 3:54 PM
December 17, 2025 - 12:00
I'm having a small problem with the Anaconda 3 package. The software refuses to install if the application folder isn't empty.
The error message is: 'Directory 'C:\ProgramData\anaconda3' is not empty, please choose a different location.'
It should be emptied after uninstalling previous versions before installing, and also after uninstalling.
Regards,
gadam
Registration: Oct 30, 2025 - 2:46 p.m.
December 18, 2025 - 09:45
Thank you for the information. We are working on it. I will keep you updated as soon as we have released the corrected package.
Gwenaël
gadam
December 18, 2025 - 1:59 PM
We have resolved the issue. The package is available in pre-production on the WAPT store here: https://wapt.tranquil.it/store/fr/detai ... EPROD.wapt
Its production release is scheduled for December 23rd at noon.
Gwenaël
