Version: 2.6.1.17472
Enterprise License
. I have Windows servers that don't seem to have their licenses activated.
Is there a way to list this using the WAPT console?
In WMI and hardware inventory, I can't find any objects that seem to match
{{ host_info.windows_product_infos.key_match }} --> always true even if it's not activated.
Any ideas if this is possible?
[SOLVED] WAPT console, checking if Windows is activated
- WAPT Expert
Hello Skoiser and Happy New Year 2026!
You can retrieve it via auditing with something like this (note: I haven't covered possible error cases):
import json
def audit():
data = run_powershell('Get-CimInstance SoftwareLicensingProduct -Filter "partialproductkey is not null" | ? name -like windows* | select Description, LicenseStatus | ConvertTo-Json')
json_data = json.loads(data)
if int(json_data['LicenseStatus'])==1:
return 'OK'
return 'WARNING'
