OS Deployment - Freeze
clafon
Registration: Nov 06, 2024 - 10:56
January 22, 2026 - 3:20 PM
Yes, it does exist
Screenshot 2026-01-22 151939.png (13.38 KB) Viewed 55374 times
My DHCP:
Screenshot 2026-01-22 152350.png (10.02 KB) Viewed 55,372 times
January 22, 2026 - 4:40 PM
In the DHCP settings, what about the `snponly_custom` option that was just manually created?
Did you correctly re-enter the " -UserClass NE,iPXE -VendorClass NE,legacy_bios*"?
Alternatively, using PowerShell:
Add-DhcpServerv4Policy -Name "snponly_custom.efi" -Condition AND -UserClass NE,iPXE -VendorClass NE,legacy_bios*
Set-DhcpServerv4OptionValue -PolicyName "snponly_custom.efi" -OptionID 67 -Value "snponly_custom.efi"
clafon
January 22, 2026 - 4:41 PM
Created manually with the following options:
Conditions: AND
User Class NEq iPXE
Provider Class NEq PXEClient (BIOS x86 & x64)*
Option 066: @WAPT server IP
Option 067: snponly_custom.efi
clafon
January 23, 2026 - 07:48
sfonteneau wrote: ↑January 22, 2026 - 4:40 PM
I deleted my manual registration and tried to place your order:
Add-DhcpServerv4Policy: The specified Vendor legacy_bios class does not exist on DHCP server SRV-XX.
At character Line:1 : 1
+ Add-DhcpServerv4Policy -Name "snponly_custom.efi" -Condition AND -Use ...
+ CategoryInfo: ObjectNotFound: (SRV-XX:root/Microsoft/...pServerv4Policy) [Add-DhcpServerv4Policy], CimException
+ FullyQualifiedErrorId: DHCP 20044,Add-DhcpServerv4Policy
January 23, 2026 - 10:16
This means that your legacy_bios class does not exist (did you not follow the original documentation?)
# Define DHCP Classes
Add-DhcpServerv4Class -Name "legacy_bios" -Type Vendor -Data "PXEClient:Arch:00000" -ErrorAction SilentlyContinue
Add-DhcpServerv4Class -Name "iPXE" -Type User -Data "iPXE" -ErrorAction SilentlyContinue
clafon
January 23, 2026 - 11:15
The DHCP declaration was made by the technician during the setup of the WAPT server by COMIT.
January 23, 2026 - 11:41
Perhaps it's simply that the "vendor" class doesn't have the name "legacy_bios"
January 27, 2026 - 4:46 PM
After troubleshooting over the phone, it appears the problem stems from a PC lacking "Microsoft Windows Production PCA 2011" (secure boot)
You would need to confirm on the PC that this is indeed the case using the PowerShell command as administrator:
[System.Text.Encoding]::ASCII.GetString((Get-SecureBootUEFI db).bytes) -match 'Microsoft Windows Production PCA 2011'
Can you check?
This was planned, and therefore the new version of Wapt allows you to create a WinPE with CA 2023 (latest version)
However, WinPE will not be visible on older models that do not have "Microsoft Windows Production PCA 2011"
This small package allows you to try and get the old PC to install CA 2023:
    registry_set(HKEY_LOCAL_MACHINE,r'SYSTEM\CurrentControlSet\Control\SecureBoot','AvailableUpdates',64)
    run_task(r'\Microsoft\Windows\PI\Secure-Boot-Update')
def audit():
    if not run_powershell("Confirm-SecureBootUEFI"):
        print("secure boot not enable")
        return "OK"
    if run_powershell(r"[System.Text.Encoding]::ASCII.GetString((Get-SecureBootUEFI db).bytes) -match 'Windows UEFI CA 2023'"):
        return "OK"
        print('Windows UEFI CA 2023 not found')
        return "ERROR"
clafon
January 28, 2026 - 4:02 PM
So, to summarize:
to be launched on one of the new positions:
on one of the old workstations, make a package with:
def audit():
        return "OK"
        return "OK"
        return "ERROR"
and see if it installs properly?
January 28, 2026 - 4:33 PM
Actually, the first step is just to check what it returns:
On your PC
I assume your new PC doesn't have "Microsoft Windows Production PCA 2011"
Answer
