Error in package description from the Microsoft Store
Answer
Vincent38
Registration: May 22, 2023 - 12:13
January 28, 2026 - 1:09 PM
I've just noticed a small error in the package download/creation template from the Microsoft Store app.
I downloaded a package from the Microsoft Store (the ChatGPT desktop client) using the "template Microsoft Store app" package, and it works perfectly, except for one small detail: the description of the generated package is the same as the "template Microsoft Store app" package :D
, and the option to fill in/edit the description no longer appears during import.
Is it possible to fix this?
And ideally, to add the ChatGPT desktop client to the Wapt store?
Thank you
. Regards
gadam
Registration: Oct 30, 2025 - 2:46 p.m.
January 29, 2026 - 11:58
We have fixed the function that retrieves and populates the description information in the package. You can download it from our store in PREPROD here: https://wapt.tranquil.it/store/fr/detai ... EPROD.wapt
It will be released to PROD in 5 days.
Best regards,
Gwenaël
Vincent38
January 29, 2026 - 12:19
Hello, perfect, thank you!
Regards
Answer
