[RESOLVED] SSL on WAPTHttpServer secondary repository
sterobo
Registration: July 24, 2025 - 3:20 PM
February 2, 2026 - 1:49 PM
Using Python and import requests, I get the same error, but with curl, it seems to work:
<!DOCTYPE html><html><body style="font-family:verdana"><h1>WAPTHttpServer Server Error 404</h1><hr><p>HTTP 404 Not Found</p><p>Wrong route</p><small>mORMot 2</small></body></html>
February 2, 2026 - 1:54 PM
curl with "--cacert"?
sterobo
February 2, 2026 - 1:56 PM
Yes: curl https://<fqdn du dépôt> --cacert "C:\Program Files (x86)\wapt\ssl\server\ca.crt"
February 2, 2026 - 1:59 PM
So what does this return?
viewtopic.php?p=16771#p16771
sterobo
February 2, 2026 - 2:06 PM
For me, the same error as wapt-get update:
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 464, in _make_request
    self._validate_conn(conn)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 1093, in _validate_conn
    conn.connect()
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 790, in connect
    sock_and_verified = _ssl_wrap_socket_and_match_hostname(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connection.py", line 969, in _ssl_wrap_socket_and_match_hostname
    ssl_sock = ssl_wrap_socket(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\ssl_.py", line 480, in ssl_wrap_socket
    ssl_sock = _ssl_wrap_socket_impl(sock, context, tls_in_tls, server_hostname)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\ssl_.py", line 524, in _ssl_wrap_socket_impl
    return ssl_context.wrap_socket(sock, server_hostname=server_hostname)
  File "ssl.py", line 513, in wrap_socket
  File "ssl.py", line 1104, in _create
  File "ssl.py", line 1375, in do_handshake
ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 787, in urlopen
    response = self._make_request(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 488, in _make_request
    raise new_e
urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)
The above exception was the direct cause of the following exception:
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 644, in send
    resp = conn.urlopen(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\connectionpool.py", line 841, in urlopen
    retries = retries.increment(
  File "C:\Program Files (x86)\wapt\lib\site-packages\urllib3\util\retry.py", line 519, in increment
    raise MaxRetryError(_pool, url, reason) from reason  # type: ignore[arg-type]
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='<fqdn du dépôt>', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)')))
  File "<console>", line 1, in <module>
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 73, in get
    return request("get", url, params=params, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "C:\Program Files (x86)\wapt\lib\site-packages\requests\adapters.py", line 675, in send
    raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='<fqdn du dépôt>', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1017)')))
February 3, 2026 - 9:45 AM
I'm a bit stuck; it seems surprising that curl accepts it but not Python.
Could you try setting the secondary repository in the "Main repository URL" configuration to HTTPS in the WAPT console
and then clicking "Verify" to see if that helps?
sterobo
February 3, 2026 - 9:56 AM
Yes, I've already tried that and it works, and I do have a line in access443.log:
x.x.x.x - - [02/Feb/2026:08:55:42 +0000] "HEAD /wapt/ping HTTP/1.1" 200 176 "https://<fqdn du dépôt>" "waptconsole/2.6.1.17472W"
February 4, 2026 - 1:57 PM
I'm a bit stuck; it seems Python is rejecting the certificate, but the console is working...
The last time I saw that, it was an antivirus program that was performing a MITM attack in the middle of a certain application.
to try :
import waptlicences
waptlicences.get_peer_cert_chain_from_server("https://reposecondaire",r"C:\waptdev\test")
To retrieve the certificate, see...
sterobo
February 4, 2026 - 3:48 PM
Mmmh, I have this:
AttributeError: module 'waptlicences' has no attribute 'get_peer_cert_chain_from_server'
However, waptcrypto.get_peer_cert_chain_from_server returns [ <SSLCertificate cn='<fqdn du dépôt>' fingerprint=xxxxxx issuer='<Mon AC>' validity=202x-xx-xx - 20xx-xx-xx Code-Signing=False CA=False> ]
While it seems to me that he should also return the intermediate and the AC...
sterobo
February 6, 2026 - 3:04 PM
The problem seems to be solved with a more recent version of wapthttpserver.exe (the latest one to be precise), I can go away for the weekend with peace of mind! Thanks for the help, Simon!
