[SOLVED] Issues in the documentation (or on the tranquil.it repo)
jmorillo
Registration: Oct 16, 2024 - 3:26 p.m.
February 5, 2026 - 9:05 AM
Hello everyone!
In the documentation: https://www.wapt.fr/fr/doc/wapt-server- ... r-packages
It is recommended to install the GPG key using this command:
sudo bash -c 'wget -qO- https://wapt.tranquil.it/$(lsb_release -is)/tiswapt-pub-2026.gpg > /usr/share/keyrings/tiswapt-pub.gpg'
On Ubuntu, we are therefore trying to retrieve the 2026 key from https://wapt.tranquil.it/Ubuntu/tiswapt-pub-2026.gpg but we get a 404
The trick to unlocking it is to go and retrieve the key from https://wapt.tranquil.it/Debian/tiswapt-pub-2026.gpg
IMHO, the tiswapt-pub-2026.gpg key should also be placed on https://wapt.tranquil.it/Ubuntu/or, failing that, update the documentation ;)
This is my first message of the year, and even though it's February 5th, I'd like to wish everyone a happy new year!
Kisses
Jordi
February 5, 2026 - 9:31 AM
Hi Jordi!
And Happy New Year 2026! :-)
Thanks for the message, indeed it was my fault... Trixie changed some constraints on GPG keys at the beginning of the month and I had to update the signatures, and I took the opportunity to update Ubuntu as well, figuring it would probably be necessary soon too...
It's fixed!
See you soon,
jmorillo
February 5, 2026 - 9:45 AM
Thank you so much, Denis!
Best of luck to the whole team, and may 2026 be filled with success!
Where I come from, we say "Hack the Planet!"
For you, I'd say "Conquer the World!" ;)
