[RESOLVED] Self-Service and the current user
stan
Registration: May 26, 2025 - 10:16 p.m.
February 12, 2026 - 11:05
I'm posting this because I have a question.
I created a custom package to install Proton Authenticator; it's an MSI installation, but the installation path is the local appdata directory of the user who launched the MSI.
I wanted to add it to the Self-Service menu so that Proton Authenticator could be installed by anyone. However, with the Self-Service menu, it installs for the "System" user, and even with `session_setup()`, I can't do that. Could you
please clarify this for me? :D
Stan
Information:
OS Administration : Windows 11 25H2
OS Server : Debian 12
WAPT Version : 2.6.1.17813
VSCode Version : 1.116.0
February 12, 2026 - 11:24
Good morning
stan wrote: ↑Feb 12, 2026 - 11:05 even with a session_setup() I can't do it.
Why can't you? In this case, the session_setup should be correct
stan
February 12, 2026 - 11:41
sfonteneau wrote: ↑Feb 12, 2026 - 11:24 Good morning
I can't use the self-service*
I tried something like that for self-service, but it doesn't work:
    session_setup()
def session_setup():
    bin_name = glob.glob("ProtonAuthenticator*.msi")[0]
    install_msi_if_needed(bin_name)
    print("Proton Authenticator a été installé")
Do you have a way to install it for the user who clicks install instead of installing it on the System user?
Stan
Information:
February 12, 2026 - 11:49
A small correction to your code
    filecopyto(bin_name , r'c:\test.msi')
    bin_name = r'c:\test.msi'
stan
February 12, 2026 - 12:07
Thank you so much, it works now.
Do you have any ideas for uninstalling it?
Running "run('msiexec /x' + bin_name + '/q')" doesn't work.
Stan
Information:
February 12, 2026 - 2:09 PM
Hi Stan,
the equivalent of the `uninstall()` function for cleaning up user sessions is the `session-cleanup()` function. It runs in the user context with the user's privileges.
https://www.wapt.fr/en/doc/wapt-create- ... on-cleanup
Regards,
stan
February 13, 2026 - 3:16 PM
thank you very much, I wasn't aware that this function existed; it must be quite recent.
Have a good day!
Stan
Information:
stan
February 13, 2026 - 3:59 PM
dcardon wrote: ↑Feb 12, 2026 - 2:09 PM Hello Stan,
the equivalent of the uninstall() function for cleaning up user sessions is the session-cleanup() function. It runs in the user context with the user's privileges.
Regards,
Hello again,
After trying the session_cleanup() function, nothing happens...
Here is my code:
def session_cleanup():
    run("msiexec /x " + new_path + " /qn")
    remove_file(new_path)
The command works fine with my user but on the other hand does not work with the "session_cleanup()" function, even when using "wapt-get session-setup packagename" nothing happens.
Thank you for being able to enlighten me :D
Have a good weekend!
Stan
Information:
February 13, 2026 - 6:00 PM
In order:
- Increment the version of the package containing session_cleanup
- install the package with this new version
- uninstall the package
- run the command `wapt-get session-setup ALL`
stan
March 17, 2026 - 11:06
After performing the operation about ten times, nothing happens.
Here is my script:
new_path = makepath(programdata(), "wapt", "ProtonAuthenticator.msi")
    filecopyto(bin_name , new_path)
    if isfile(new_path):
        print("Proton Authenticator a été copié dans " + new_path)
        return
        print("Erreur lors de la copie de Proton Authenticator dans " + new_path)
        return "ERROR"
    try:
        install_msi_if_needed(new_path)
    except Exception as e:
        print("Erreur lors de l'installation de Proton Authenticator : " + str(e))
        return "ERROR"
    return "OK"
    run("msiexec /X" + new_path + " /qn")
When I enter the commands, I get this:
C:\Users\stan>wapt-get remove X-proton-authenticator
Désinstallation de X-proton-authenticator mis en file d'attente
Désinstallé(s) : X-proton-authenticator
C:\Users\stan>wapt-get session-cleanup ALL
1
0
It went from 1 to 0 so for me it should work but it doesn't.
However, if I execute the line in CLI "msiexec /XProtonAuthenticator.msi /qn" it works fine.
Thanks in advance :)
Stan
Information:
