I'm using WAPT 2.6.1.17705, Enterprise Edition, Debian 11, and I'm administering it on Windows 10.
My main repository is full, and I can't increase the storage space on the machine. What's the simplest solution: move the repository (/var/www/wapt/) to another folder where a storage server is mounted, or create a second repository in addition to the first one, pointing to the storage server?
Thank you.
[RESOLVED] Full deposit
- WAPT Expert
all the time
- Registration: March 2, 2026 - 4:40 PM
OK, it seems to be working well:
Copying the old folder to the new one (I did a cp without -a, maybe that was a mistake) /new/wapt
renaming the old folder to waptold
Creating symbolic links for the applications waptsetup.exe, waptdeploy.exe, and waptsetup-tis.exe to point to the waptagent folder in the new location
ex. : /new/wapt/waptdeploy.exe -> waptagent/waptdeploy.exe
changing permissions with chown of the new folder
creating the wapt symbolic link in /var/www/ pointing to the new location
deletion of the old file
I have updated packages without any problems and I am going to do the latest WAPT upgrade.
sudo chown -R wapt:www-data /nouveau/waptCode: Select all
sudo ln -s /nouveau/wapt waptI have updated packages without any problems and I am going to do the latest WAPT upgrade.
- WAPT Expert
Hi Romain,
thanks for the feedback.
I'm marking the topic as resolved.
