DWORD registry value - prohibiting an executable
Gaelds
Registration: Nov 22, 2015 - 08:37
February 6, 2017 - 10:34
I'm having trouble adding a DWORD value to the registry; I get the following message when running session-setup:
CRITICAL ValueError: Could not convert the data to the specified type.
It's the same with the values ​​1 or 0x00000001.
import time
import os
def GetUserName():
    return os.getenv('USERNAME')
    print('Installation de DisallowRun')
def session_setup():
    utilisateur = GetUserName()
    if(utilisateur == "eleve"):
        registry_set(HKEY_CURRENT_USER,r'Software/Microsoft/Windows/CurrentVersion/Policies/Explorer/','DisallowRun','0x00000001',type=REG_DWORD)
        registry_set(HKEY_CURRENT_USER,r'Software/Microsoft/Windows/CurrentVersion/Policies/Explorer/DisallowRun','1','shutdown.exe',type=REG_SZ)
February 6, 2017 - 10:46
    if (get_current_user() == "eleve"):
        registry_set(HKEY_CURRENT_USER,r'Software/Microsoft/Windows/CurrentVersion/Policies/Explorer/','DisallowRun',1,type=REG_DWORD)
Gaelds
February 6, 2017 - 10:48
I just found another registry_set syntax in a message on the wapt mailing list and apparently it works:
registry_set(HKEY_CURRENT_USER,r'Software/Microsoft/Windows/CurrentVersion/Policies/Explorer/', r'DisallowRun', 1, REG_DWORD)
Even after the shutdown.exe program is still not blocked for the student user, that's another problem...
Gaelds
February 6, 2017 - 11:21
Ah sorry, our previous messages must have crossed paths, otherwise I tested another method with iCalcs to block access to shudown.exe.
        print('interdiction de shutdown.exe pour eleve')
        run(r'takeown /F %windir%\system32\shutdown.exe')
        run(r'icacls %windir%\system32\shutdown.exe /deny eleve:D')
The command lines work in manual mode, but in session-setup, it has no effect, nor does it produce an error message.
