[SOLVED] Enable WUA without auto download/install
Olivier Schmitt
Registration: Oct 22, 2024 - 1:25 p.m.
March 12, 2026 - 3:38 PM
I would like to know if it is possible to configure WUA activation but without:
download_scheduling=10h
install_scheduling=1h
The goal is to be able to control the day and time of the update application using a Windows task with:
"C:\Program Files (x86)\wapt\wapt-get.exe" waptwua-download
"C:\Program Files (x86)\wapt\wapt-get.exe" waptwua-install
Or should we enter a value like 0 or none?
download_scheduling=0h
install_scheduling=0h
Thank you in advance.
March 12, 2026 - 3:48 PM
the simplest solution would probably be to not include
install_scheduling.
Olivier Schmitt
March 12, 2026 - 4:48 PM
thank you for your feedback.
I wanted to be certain that there is no default value.
March 12, 2026 - 5:08 PM
The default value is None.
And to set it to None, you must leave it blank. :)
Olivier Schmitt
March 13, 2026 - 1:48 PM
THANKS!
