I've set up the RustDesk remote access solution following the tutorial here: https://wapt.tranquil.it/store/fr/tis-rustdesk
. It's working.
However, I have a question: is it possible to adjust the settings to only allow access from the WAPT console (and/or only from the IT admin PCs)?
Currently, any client PC with the RustDesk package can open RustDesk on its desktop and take control of any PC on the network if they have the ID and password.
Perhaps I've missed a configuration setting somewhere.
Thank you and have a good day!
[SOLVED] RustDesk package configuration
- WAPT Expert
Actually, if you use https://wapt.tranquil.it/store/fr/tis-r ... g-template
, it sets a random password for each RustDesk configuration.
This password is then sent to the WAPT server in encrypted form using a certificate already deployed on the machine.
Therefore, only an administrator (who has a WAPT certificate) can currently access a machine.
Yes, it already works.
- WAPT Expert
Hello admmelyne,
were you finally able to set up your integrated Wapt Rustdesk?
Regards,
Regards,
By modifying the file C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\RustDesk\config\RustDesk2.toml, it is possible to limit the IP addresses allowed to launch a remote takeover.
[options]
whitelist ='IP1,IP2,IP3'
Wapt Enterprise Edition 2.6.1.17765
WAPTConsole Enterprise on Windows
WAPT Server on Debian 12
- WAPT Expert
@tux thanks for the suggestion, we'll add it to the default file and mention it in the README.
@admmelyne, since I don't hear back, I'll assume it's okay and mark the topic as RESOLVED (it would be nice to get some feedback though...)
