Winpe
Answer
Catherine
Registration: March 26, 2026 - 4:16 PM
March 26, 2026 - 4:41 PM
I downloaded WinPE,
then booted my PC into PXE mode, and at a certain point, a command prompt window appeared displaying this message: "
Fying JSO with signer certificate: wapt_private_admin. Verification of
wads64.exe signature failed: ERROR: Signet wapt_private_admin (sha256 c6d0661e1216590
0a81b9a30ebbd7637c770884650506606ffd3031507b40fa) is not trusted. Reason: self-signed certificate
"wapt_private_admin" is not a trusted certificate. Aborting
X:\Windows\System32>"
. Could you please help me?
Do you also have the correct procedure for downloading WinPE? Thank you in advance.
Have a good day.
Screenshot 2026-03-26 162101.png (243.11 KB) Viewed 13704 times
March 26, 2026 - 5:58 PM
it seems that wads.exe is signed with the "wapt_private_admin" certificate, which is not included in WinPE.
Have you changed the key?
Go to the Tools menu ‣ Sign Deploy Exe.
Catherine
March 31, 2026 - 4:06 PM
please excuse the delay in my response.
Thank you for the information; I will look into it and also check other points.
I will get back to you if necessary.
Sincerely.
Catherine
May 28, 2026 - 2:01 PM
the problem has been resolved.
Thank you in advance. (Configuration issue)
Answer
