[RESOLVED] SSL on WAPTHttpServer secondary repository
sterobo
Registration: July 24, 2025 - 3:20 PM
February 11, 2026 - 3:10 PM
Sorry to repost here but the problem only seems to be partially resolved with version 2.6.1.17705 of wapthttpserver (client in 2.6.1.17472).
A wapt-get install works, but as soon as I run a wapt-get update from a client, wapthttpserver no longer seems to respond to requests.
After restarting the wapthttpserver service, it's working again.
2026-02-11 15:04:17,812 INFO Read Packages index file for repo wapt
2026-02-11 15:04:17,812 DEBUG Read remote Packages zip file https://<fqdn du dépot secondaire>/wapt/Packages
2026-02-11 15:04:17,812 DEBUG Loading ssl context with cert C:\Program Files (x86)\wapt\private\<client>.crt and key C:\Program Files (x86)\wapt\private\<client>.pem
2026-02-11 15:04:17,812 DEBUG Starting new HTTPS connection (1): <fqdn du dépot secondaire>:443
2026-02-11 15:04:17,828 DEBUG https://<fqdn du dépot secondaire>:443 "GET /wapt/Packages HTTP/1.1" 200 205076
2026-02-11 15:04:27,832 INFO Unable to update repository status of https://<fqdn du serveur wapt>/wapt, error HTTPSConnectionPool(host='<fqdn du dépot secondaire>', port=443): Read timed out.
2026-02-11 15:04:27,832 DEBUG Transaction took too much time : 10.019804000854492
2026-02-11 15:04:27,839 DEBUG Error at DB exit HTTPSConnectionPool(host='<fqdn du dépot secondaire>', port=443): Read timed out., rollbacking
sterobo
April 3, 2026 - 3:11 PM
Problem apparently resolved since version 2.6.1.17765 of wapthttpserver
