[SOLVED] parsec-cloud update_package issue
esberard
Registration: Oct 09, 2023 - 11:35
April 13, 2026 - 3:06 PM
There seems to be a problem with the parsec-cloud update package:
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
April 13, 2026 - 3:21 PM
The latest Windows version doesn't seem to be available on the GitHub API. On the GitHub website, the link to the executable returns a 404 error.
I'll see if I can find the binary through another method besides GitHub.
Ingrid
italbot
April 14, 2026 - 2:04 PM
I'm unable to retrieve the version and binary except through GitHub, and I've contacted the Parsec Cloud developers. The latest release doesn't support Windows, which is why the link returns a 404 error.
On our store, the software remained at version 3.7.1 because, at the time of its creation, the package wasn't monitored to update with each version change. I've just corrected this. The software will be up-to-date on our store with the next Windows release.
Ingrid
esberard
April 15, 2026 - 09:27
Thank you so much
