Description:
Oracle VM VirtualBox with Extension Pack.
The VirtualBox binaries are released under the terms of the GPL version 2.
The Extension Pack binaries are released under the VirtualBox Personal Use and Evaluation License (PUEL).
See https://www.virtualbox.org/wiki/Downloads
Package: tis-virtualbox
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
Steven Samson - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires
Version 4.3.26
Changelog:
https://www.virtualbox.org/wiki/Changelog
In session_setup, non-free extensions are registered. This is not silent.
Therefore, VirtualBox is launched at login and asks to accept the installation.
Changelog:
The VirtualBox 5.1.14-4 package is not installing correctly on Windows 10 64-bit (non-zero exit status 1).
I tried downloading the VirtualBox installer from the Oracle website "VirtualBox-5.1.14-112924-Win.exe" and running it with the --silent parameter, but the silent installation is not working.
David Rouet
VirtualBox Installer
-- VirtualBox Installer v5.1.14.112924 --
Command Line Parameters:
--extract - Extract file contents to temporary directory
--help - Print this help and exit
--logging - Enables installer logging
--msiparams
--no-silent-cert - Do not install VirtualBox Certificate automatically when --silent option is specified
--path - Sets the path of the extraction directory
--reinstall - Forces VirtualBox to get re-installed
--silent - Enables silent mode installation
--version - Print version number and exit
Examples:
VirtualBox-5.1.14-112924-Win.exe --msiparams INSTALLDIR=C:\VBox
VirtualBox-5.1.14-112924-Win.exe --extract -path C:\VBox
OK
David Rouet
--msiparams
Examples:
OK
- WAPT Expert
I just tried the package:
https://wapt.tranquil.it/package_detail ... 4_all.wapt
It uses --silent.
It works.
It uses --silent.
It works.
