[SOLVED] Problem with tis-laps Linux
jptw
Registration: July 8, 2020 - 11:08 AM
April 1, 2026 - 4:23 PM
I have a WAPT server running Debian 10 (
console version 2.6.0.16937) and
a client running Debian 12.
I'm trying to use the tis-laps package to retrieve the password for an account (adminos, for example).
The package installs correctly, but the audit fails with the error: "kerberos bind failed".
The client machine is properly joined to Active Directory via realm join, and I can log in with domain user accounts.
The audit correctly returns the hostname_from_keytab and domain_from_keytab.
Do you have any ideas?
Thank you.
April 1, 2026 - 6:02 PM
Hello
, could you try with the latest version of wapt?
You indicated 2.6.0.16937.
The package was coded with that release, and the pyldap library in wapt has had patches specifically for tis-laps.
I should have added a min_wapt_version to the package.
jptw
April 3, 2026 - 11:14
Okay, I'll test it
April 7, 2026 - 4:23 PM
Hi Jens,
were you able to solve your problem?
April 16, 2026 - 5:20 PM
Hi Jens,
since I haven't received a response, I'll assume it's okay...
I'm marking the topic as resolved.
