[RESOLVED] Self-Service and the current user
- WAPT Expert
Hi Stan,
which version of Wapt (see forum rules
- WAPT Expert
Hello Stan,
Okay, it's a recent enough version that it should work... As for the 0/1 that is returned, I'm not sure we should rely on it too much.
Just to be sure, you don't have a `def uninstall()` that deletes the file in `c:\programdata`? Does it still bug out the same way when you use the GUID from the MSI instead of its path? In the user session, the GUID does indeed match the one in the package (we've seen GUIDs generated on the fly before...)
Could you please run the command again in debug mode?
And could you add something to the function to make sure you actually go through it (like creating a file, etc.)?
Speaking of which, it's true that we could keep logs of this in %localappdata%\wapt-get, at least with the fact that it executed and the return code of the function.
wapt-get session-clean -l debugSpeaking of which, it's true that we could keep logs of this in %localappdata%\wapt-get, at least with the fact that it executed and the return code of the function.
Here is the result:
And if I do it a second time, only the 1 changes to 0....
Here is the result:
[DEBUG] Logging TSynLog with level=debug to C:\Users\X\AppData\Local\wapt-get-log\wapt-get.log
2026-04-17 16:00:14,881 DEBUG Default encoding : utf-8
2026-04-17 16:00:14,881 DEBUG Caller: ['', 'session-cleanup', '-l', 'debug']
2026-04-17 16:00:14,881 DEBUG Python path ['C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\python310.zip', 'C:\\Program Files (x86)\\wapt', 'C:\\Program Files (x86)\\wapt\\DLLs', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\win32\\lib', 'C:\\Program Files (x86)\\wapt\\lib\\site-packages\\Pythonwin']
2026-04-17 16:00:14,881 INFO Using local waptservice configuration C:\Program Files (x86)\wapt\wapt-get.ini
2026-04-17 16:00:14,881 DEBUG Config file: C:\Program Files (x86)\wapt\wapt-get.ini
2026-04-17 16:00:14,881 INFO Using openssl OpenSSL 3.5.5 27 Jan 2026
2026-04-17 16:00:14,883 DEBUG Thread 17204 is connecting to wapt db
2026-04-17 16:00:14,886 INFO User Groups:[]
2026-04-17 16:00:14,886 DEBUG Host certificate C:\Program Files (x86)\wapt\private\5f870aea-badb-4882-965a-fc5ceea3a828.crt not found, not using it for auth on repo global
2026-04-17 16:00:14,887 DEBUG 17204 Loading config from file C:\Program Files (x86)\wapt\conf.d\cfg-X-waptagent.json
2026-04-17 16:00:14,887 DEBUG 17204 Loading config from file C:\Program Files (x86)\wapt\conf.d\cfg-X-waptagent_DSN.json
2026-04-17 16:00:14,890 INFO WAPT base directory : C:\Program Files (x86)\wapt
2026-04-17 16:00:14,890 DEBUG cleanup session db, removed not installed package entries
2026-04-17 16:00:14,891 DEBUG Thread 17204 is connecting to wapt db
2026-04-17 16:00:14,893 DEBUG DB Start transaction
2026-04-17 16:00:14,894 DEBUG DB commit
1
20260417 14001455 ! rotat wapt-get 2.6.1.17765 TSynLog 2.4.13434 {12 10.08 8.94 7GB/7.7GB 23.1GB/26.7GB 66581b01}
20260417 14001455 ! info SetThreadName 1 4334 17204=Main
20260417 14001455 ! info wapt-get terminateHello Denis,
After trying quite a few things, replacing the GUID file with the MSI file finally unlocked the uninstallation. A huge thank you!
By the way, I'm offering my "proton-authenticator" package for the WAPT store, if the team is interested in adding it:
from time import sleep
new_path = makepath(programdata(), "wapt", "ProtonAuthenticator.msi")
uninstall_key = "{F91F8A3E-840F-4B27-B877-13797064C5CA}"
bin_name = glob.glob("ProtonAuthenticator*.msi")[0]
filecopyto(bin_name , new_path)
if isfile(new_path):
print("Proton Authenticator a été copié dans " + new_path)
print("Erreur lors de la copie de Proton Authenticator dans " + new_path)
return "ERROR"
def session_setup():
try:
install_msi_if_needed(new_path)
except Exception as e:
print("Erreur lors de l'installation de Proton Authenticator : " + str(e))
return "ERROR"
print("Proton Authenticator a été installé")
def session_cleanup():
r"""Supprime le raccourci du bureau de l'utilisateur
run("msiexec /x \"%s\" /qn" % uninstall_key)
sleep(2)
remove_file(new_path)
print("Désinstallation de Proton Authenticator...")
https://i.imgur.com/fHG3Vwg.png
Stan
