Deleted packages still visible in the WAPT console
Answer
thirst_for_knowledge
Registration: December 5, 2024 - 3:33 PM
April 21, 2026 - 1:48 PM
We are currently using WAPT 2.6.0.16714. The console is installed on a Windows Server 2019, and the WAPT server is hosted on Ubuntu.
I've noticed some behavior (bug or feature?) regarding the package list when modifying workstations: some packages continue to appear even though they have been correctly removed from the private repository.
Could this be related to the WAPT server cache? Do you have a solution to permanently remove packages that no longer exist in the private repository?
- Installed WAPT version: 2.6.0.16714
- Server OS: Ubuntu
- Administration machine OS: Windows Server 2019
blemoigne
Registration: July 17, 2020 - 11:29
April 21, 2026 - 5:10 PM
The packages always appear so they can be conflicted on machines that still have these packages installed.
Best regards,
Bertrand
April 22, 2026 - 09:47
blemoigne wrote: ↑Apr 21, 2026 - 5:10 PM Hello,
The packages still appear so that they can be conflicted on machines that still have these packages installed.
Best regards,
Bertrand
I thoroughly checked all the machines on the network and none of them have this package installed. I selected all the machines and then checked the packages one by one to see if it appeared in the list of installed software, but I couldn't find it anywhere.
I don't know if this method is completely reliable, but for me, the package isn't installed on any machine. Yet, it still appears in the changelog :cry:
- Server OS: Ubuntu
blemoigne
April 22, 2026 - 12:27
You need to go to "All" and then select all machines (Ctrl+A), then search for the package in the filter of installed packages (General tab on the right).
Pay attention to the number of machines displayed in the inventory; are they all present on this page?
April 22, 2026 - 3:11 PM
Yes,
they are all present and selected during my operation.
EXTERNAL IMAGE
DELETED EXTERNAL IMAGE DELETED
The package is obviously deleted from "Private Repository"
- Server OS: Ubuntu
April 22, 2026 - 5:12 PM
Hi Nam,
you need to attach the images to the post: no links to external hosting sites (for reasons of longevity and security).
I've removed the two links from your last post.
April 23, 2026 - 10:28
I would like to send the attachments but I received this error message:
"Error
The limit for the number of attachments on the forum has been reached."
- Server OS: Ubuntu
April 23, 2026 - 10:57
Hi again Nam,
sorry, there was a configuration problem (the maximum size for all attachments had been reached...). It's fixed now.
You can re-upload your attachments.
April 23, 2026 - 11:04 AM
blemoigne wrote: ↑Apr 22, 2026 - 12:27 You should go to "All" and then select all machines (Ctrl+A), then search for the package in the filter of installed packages (General tab on the right).
D,
Attached you will find images illustrating the problem.
3
3
Screenshot 2026-04-23 100901.jpg (33.76 KB) Viewed 14902 times
2
2
Screenshot 2026-04-23 100849.jpg (39.96 KB) Viewed 14902 times
1
1
Screenshot 2026-04-23 100831.jpg (39.12 KB) Viewed 14902 times
- Server OS: Ubuntu
Answer
