First, I'd like to mention that I've looked at this link:
https://dev.tranquil.it/sphinxdocs/sour ... p_shortcut
Here's how I'm trying to create my shortcut in the setup.py file:
def session_setup():
create_user_desktop_shortcut(ShortcutName,target='targetFile','my.exe')
There must be something I'm missing.
Could someone describe the command in plain English?
Thank you
Creating a desktop shortcut
I create my shortcuts in a folder on the public desktop using the "create_shortcut" function, an example of which is shown below:
Worth testing, but I think you can use:
The wDir and icon options allow you to specify the startup folder and the path to the icon.
create_shortcut(makepath(common_desktop(),'Logiciels','SketchUp 2014.lnk'),target=r'%s\SketchUp\SketchUp 2014\SketchUp.exe' %programfiles, wDir=r'%s\SketchUp\SketchUp 2014\\' %programfiles,icon=r'%s\SketchUp\SketchUp 2014\SketchUp.exe' %programfiles)
create_user_desktop_shortcut("Nom du raccourci",target=r'C:\dossier\mon.exe',wDir=r'C:\dossier\\',icon=r'C:\dossier\mon.exe')
