[RESOLVED] Bone deployment issue
Catherine
Registration: March 26, 2026 - 4:16 PM
April 27, 2026 - 1:43 PM
With wapt I prepare my PCs with wads until now everything was fine except now I get this message and I can't go any further.
The waptagent.exe can not befound on the machine*.
hashes's signature signed by: suivie des noms des certificats
et the server data is valid and correctly signed
He told me he couldn't find my waptagent.exe :roll: :roll:
Thank you for your feedback
Have a lovely day!
jarnaud
Registration: May 3, 2024 - 3:37 p.m.
April 28, 2026 - 09:38
Is the waptagent.exe binary present in your Wapt server's web interface?
Is it the same version as the watpsetup.exe binary?
You could also check this forum; the problem seems quite similar.
viewtopic.php?t=4368
Best regards
Catherine
April 28, 2026 - 09:49
yes, everything is the same:
WAPT Server version: 2.6.1.17765
WAPT Agent version: 2.6.1.17765
WAPT Setup version: 2.6.1.17765
WAPT Deploy version: 2.6.1.17765
DB status: OK
Disk space: 31.84% free
Thank you
Catherine
April 28, 2026 - 11:35
I found the solution! I just needed to go back into the tool and sign my waptagent.exe file, and it worked. :) :)
"Tools" -> "Sign executables" and sign.
Thank you for your help.
April 28, 2026 - 12:26
Hi Catherine,
thanks for the feedback. :-)
I'm marking the topic as resolved.
