Foxit package shell
Answer
Balem
Registration: August 24, 2023 - 11:45
May 4, 2026 - 4:33 PM
We are importing the Foxit package in DEV maturity to install it on a few workstations to ensure that there are no side effects.
When we switch the package to PROD, it deletes the "Foxit Software" folders but does not reinstall the software because the version is identical.
Do you think that the deletion of folders should be included in the 'if' condition to correct this typo?
THANKS
for to_uninstall in installed_softwares(name="Foxit PDF Reader"):
	if Version(to_uninstall["version"]) < Version(control.get_software_version()) or force:
		print(f"Removing: {to_uninstall['name']} ({to_uninstall['version']})")
		run(uninstall_cmd(to_uninstall["key"]))
		wait_uninstallkey_absent(to_uninstall["key"])
old_app_dir = makepath(programfiles32, "Foxit Software", "Foxit Reader")
if isdir(old_app_dir):
	remove_tree(old_app_dir)
old_app_dir = makepath(programfiles, "Foxit Software")
# Installing the package
install_exe_if_needed(
	bin_name,
	silentflags="/quiet",
	timeout=900,
	name="Foxit PDF Reader",
	min_version=control.get_software_version(),
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
May 4, 2026 - 4:59 PM
From what I can see in the code, the uninstallation in the install() function only runs if the version is lower:
If you remove this condition, the uninstallation should proceed, even if it's the same version.
You can also modify it in this way:
if Version(to_uninstall["version"]) <= Version(control.get_software_version()) or force:
Ingrid
Balem
May 5, 2026 - 08:52
Hello, thank you for this feedback. The idea is to indent the deletion of folders after uninstallation (if it occurs)
	bin_name,
	timeout=900,
italbot
May 5, 2026 - 09:10
Yes, you can do that in addition, but you will still need to modify the version comparison condition; otherwise, nothing will be uninstalled before the installation.
Ingrid
Answer
