Disable notifications
f4242
Registration: Nov 23, 2016 - 8:51 p.m.
February 23, 2017 - 8:05 PM
is it possible to disable notifications while keeping wapt in the system tray? When updating multiple packages, it spams quite a bit, and the new Windows "toast" notification system doesn't help either...
February 23, 2017 - 10:57 PM
You can add:
notify_user=0
in wapt-get.ini
https://wapt.lesfourmisduweb.org/detail ... 2_all.wapt
f4242
February 24, 2017 - 5:47 PM
Excellent, thank you!
Is this documented anywhere? I searched the documentation before posting and couldn't find anything.
EDIT: Hmm, it doesn't seem to work. I deleted a package from the console to test it, and the wapt service started sending notifications to the user.
March 15, 2017 - 11:03
Hello
, I'm unable to reproduce the problem on my end.
It works for me.
guigui
Registration: August 25, 2018 - 5:54 PM
August 25, 2018 - 7:14 PM
I'm reviving this topic, but after following the forum instructions, I still can't hide or disable WAPT notifications on my client machines. I'm quite new to WAPT; I just finished installing the agent server and everything else. These notifications are the only thing that's bothering me. Could you please help me?
Thank you in advance.
