we've been having issues for some time with the management of audit log storage on the server in the database, which tends to cause it to grow unnecessarily large.
There's a discrepancy between the retention parameters we specify in our audit package and the parameters the server uses.
For example, max_count=10, keep_days=30.
The WAPT agent correctly uses both parameters with their values, but the WAPT server only uses keep_days and not max_count. This means, for example, that for an audit using the LLDP protocol we've implemented, which retrieves the switch and the workstation's connection port, we've specified max_count as 10 and keep_days as 365 to only retain the last 10 audit logs over 365 days. However, the server doesn't take max_count into account, only keep_days. This results in one audit of the packet every 2 hours for 365 days across nearly 9,000 machines... you can imagine the volume; it represented 8 GB in the database audit table.
Another problematic audit is BitLocker. There are 1,117,000 BitLocker key audits for almost 9,000 machines. In fact, the encryption value is different with each audit, generating a new entry. We're looking at approximately 600 BitLocker audit entries per machine in the database.
Currently, the WAPT audit table represents 40 GB out of the database's total 49 GB.
I think there are things that need improvement to prevent this database from exploding with audit management.
Thank you for your feedback,
Rémy Esberard
Problem of audits overloading the database
- WAPT Expert
Hi Rémy,
actually the max_count only concerns the database of the local WAPT agent. The server only relies on keep_days; that's how it performs cleanup.
If the server were listening to the agent's max_count, the WAPT agent could modify its history with the max_count, which wasn't the intended behavior.
In the case of BitLocker, it's indeed an error because the package does use if_changed , but... since it also uses rsa_encrypted_data_str, it gets updated every time because rsa_encrypted_data_str is encrypted differently each time. It's definitely an error in the package; we need to look into improving it.
For example, we could implement a max_count on the server side, but not one decided by the client.
