[RESOLVED] tis-onlyoffice-desktop problem with ONLYOFFICE Update Service
esberard
Registration: Oct 09, 2023 - 11:35
May 26, 2026 - 3:24 PM
The latest update of OnlyOffice Desktop Editor (9.4.0.129) seems to remove the "ONLYOFFICE Update Service" during the update process on a number of machines, causing the update to time out.
Do you have any suggestions for a fix?
Thank you
, Rémy
Mikael S
Registration: January 20, 2025 - 3:54 PM
May 27, 2026 - 11:18
We're mainly experiencing a runtime error when launching the setup.
Without acknowledging the error message, the installation doesn't continue.
We switched to the MSI file instead of the executable. There are no longer any problems with this version.
Regards,
May 27, 2026 - 2:25 PM
Hi Rémi and Mickaël,
we're trying to prioritize the .exe file over the .msi file, given the number of workstations having problems with their msiexec environment (the .msi format was supposed to solve the .exe installation problems, but it also came with its own set of issues).
We're disabling the service to prevent the software from updating itself without the sysadmin's approval. But if the autoupdate refuses to be disabled, things get complicated...
We'll see if we can resolve the issue by stopping the service. Otherwise, we'll switch to the .msi file.
Best regards,
slegurun
Registration: May 29, 2026 - 4:23 p.m.
May 29, 2026 - 4:28 PM
I have to change line 20 of setup.py
: silentflags="/VERYSILENT /NORESTART /SUPPRESSMSGBOXES",
there's a missing 'P' in /SUPPRESSMSGBOXES.
Regards,
Sylvain
Mikael S
June 1, 2026 - 09:31
I hadn't seen that one, but yes, that's the right solution.
Regards,
gadam
Registration: Oct 30, 2025 - 2:46 p.m.
June 1, 2026 - 3:46 PM
We have fixed the package; it is available in pre-production on our store here: https://wapt.tranquil.it/store/fr/detai ... EPROD.wapt
It should go into production on June 6, 2026.
Gwenaël
