Add the computers to a group during registration
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
April 21, 2016 - 11:07
I would like to automatically assign a computer to a group as soon as it is added to WAPT.
Is it possible to do this with a command line on the client machine?
Or from the server with a script that runs continuously?
Thank you.
April 22, 2016 - 12:30 AM
No method to (basically) create the host machine package
But another method amounts to much the same thing:
Following the launch of waptdeploy, you can add a:
wapt-get install groupdebase
The other solution (which amounts to the same thing) is to add a line in the [Run] section of the file C:\wapt\waptsetup\waptsetup.iss
Filename: "{app}\wapt-get.exe"; Parameters: "--direct apt-get install groupedebase"; Flags: runhidden postinstall; StatusMsg: StatusMsg: {cm:groupedebase}; Description: "{cm:groupedebase}"
Don't forget to also add groupedebase to [CustomMessages]:
[CustomMessages]
;English translations here
en.StartAfterSetup=Install base groupe
;French translations here
fr.StartAfterSetup=Install base groupe
;German translation here
de.StartAfterSetup=Install base groupe
Then restart the creation of a Waptagent
The problem with these two commands is that they are launched with the account that launched the waptagent (or the waptdeploy)
In itself, nothing serious, but if the installation is performed at computer startup or shutdown, it can be problematic if the `preshutdowntimeout` setting hasn't been changed on the computer. Otherwise, the installation will stop after 15 minutes
Daniel Traversa
Registration: February 21, 2017 - 2:26 PM
March 2, 2017 - 3:42 PM
I would also like to do something similar:
The customer settles in, the station takes the group and proceeds with the installations.
I followed this procedure to register the position in the group and perform an upgrade, but without success.
In the waptsetup.iss file:
[Run]
Filename: "{app}\wapt-get.exe"; Parameters: "--direct apt-get install 08307_coudon-groupe-commun"; Flags: runhidden postinstall; StatusMsg: StatusMsg: {cm:groupedebase}; Description: "{cm:groupedebase}"
Filename: "{app}\wapt-get.exe"; Parameters: "--direct apt-get upgrade"; Flags: runhidden postinstall; StatusMsg: StatusMsg: {cm:upgrade}; Description: "{cm:upgrade}"
[CustomMessages]
en.groupedebase=Install base groupe
en.upgrade=Install
fr.groupedebase=Install base groupe
fr.upgrade=Install
de.groupedebase=Install base groupe
de.upgrade=Install
Can you help me?
THANKS.
Daniel Traversa
March 3, 2017 - 3:38 PM
Isn't there an error in the order?
when I type on the post:
C:\wapt>wapt-get.exe --direct apt-get install 08307_coudon-groupe-commun
I have :
Unknown action apt-get
THANKS
Daniel Traversa
March 3, 2017 - 4:02 PM
if I use the group registration command:
wapt-get install 08307_coudon-groupe-commun
The registration process on the workstation goes smoothly, then the packages are downloaded and installed.
On the other hand, nothing happens on the console: the workstation remains without a group, nothing is visible in the ongoing tasks and in General there is no monitoring of the installation.
Obviously, if we launch an update of the available packages, it will update itself.
Is this normal operation? If so, it's not very practical for ensuring the installation is working correctly after restoring a workstation.
