Bone deployment problem
Answer
Catherine
Registration: March 26, 2026 - 4:16 PM
June 1, 2026 - 4:29 PM
I'm contacting you because I'm having a deployment issue with WADs.
I created a certificate for a colleague so he could use the console and perform WADs deployments.
When he has to choose the driver, he needs to sign in, but he gets this error message:
( I created two certificates for colleagues so they could perform WADs deployments, and this message appears when he's trying to select the OS or even the driver, where he has to enter the password.
If possible, could you provide the complete procedure for creating the certificate and the permissions he needs to deploy? The certificates I created are on a VM, and then I copy them and place them where they need to be.
Thank you for your help.
Have a great day.
error signature.PNG (22.06 KiB) Viewed 5725 times
blemoigne
Registration: July 17, 2020 - 11:29
June 1, 2026 - 6:12 PM
what is the content of the directory C:\Users\u08341\private? Does it contain the public and private keys (crt and pem)?
If both files are present, then the password entered is incorrect.
Bertrand
Answer
