Following the WAPT server update, the console connection no longer works.
We receive the following message:
"Login error: Http client error: THttpClientSocket.OpenBind: Is a server available on this address:port? {remoteip=]{#6 Fatal Error]"
We use Active Directory authentication to connect to the console.
Our WAPT server is installed on Debian 13 with WAPT 2.6.1.17765.
The console is installed on Windows 10.
Thank you in advance for your help,
Céline
WAPT console access error
- WAPT Expert
Hi Céline,
which version of Wapt and Debian did you upgrade from?
When you upgraded, I imagine you also updated the Debian packages? Was nginx updated?
Is nginx running correctly on the server? Is the spnego package the same version as the nginx server (nginx is very particular about this)?
And did the waptserver service itself upgrade correctly?
Best regards,
Best regards,
I upgraded from Debian 12 to Debian 13.
And yes, nginx was also updated. It's now version 1.26.3.
The libnginx-mod-http-auth-spnego package is version 1.1.3.
I updated WAPT to version 2.6.1.17813.
On my server's web page, everything is up to date.
Céline
Céline
- WAPT Expert
Hello Céline,
what's your problem with a
The spnego package is indeed the one from Debian (previously in Debian 12 and below Tranquil IT recompiled and provided the spnego module, since deb13 it is included by default in the Debian repositories)?
nginx -TCode: Select all
apt info libnginx-mod-http-auth-spnego | grep "Maintainer:"Denis
Denis,
Thank you for your feedback.
Here is the output of the nginx -T command
I don't know about spnego, but here's the order response:
Sincerely
Celine
2026/06/12 10:09:59 [warn] 56020#56020: "ssl_stapling" ignored, no OCSP responder URL in the certificate "/opt/wapt/waptse rver/ssl/cert.pem"
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
# configuration file /etc/nginx/nginx.conf:
user www-data;
worker_processes auto;
worker_cpu_affinity auto;
worker_rlimit_nofile 32768;
pid /run/nginx.pid;
error_log /var/log/nginx/error.log;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 4096;
http {
sendfile on;
tcp_nopush on;
types_hash_max_size 2048;
server_tokens off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_prefer_server_ciphers off;
access_log /var/log/nginx/access.log;
gzip on;
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
# configuration file /etc/nginx/modules-enabled/50-mod-http-auth-spnego.conf:
load_module modules/ngx_http_auth_spnego_module.so;
# configuration file /etc/nginx/mime.types:
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/avif avif;
image/png png;
image/svg+xml svg svgz;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/webp webp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
font/woff woff;
font/woff2 woff2;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.oasis.opendocument.graphics odg;
application/vnd.oasis.opendocument.presentation odp;
application/vnd.oasis.opendocument.spreadsheet ods;
application/vnd.oasis.opendocument.text odt;
application/vnd.openxmlformats-officedocument.presentationml.presentation
pptx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
xlsx;
application/vnd.openxmlformats-officedocument.wordprocessingml.document
docx;
application/vnd.wap.wmlc wmlc;
application/wasm wasm;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xslt+xml xsl xslt;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/ogg ogv;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-matroska mkv;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/wapt.conf:
limit_req_zone $proxy_add_x_forwarded_for zone=wsgi:20m rate=100r/s;
limit_req_zone $proxy_add_x_forwarded_for zone=login:20m rate=2r/s;
limit_req_zone $proxy_add_x_forwarded_for zone=websockets:20m rate=300r/s;
log_format combined_ssl '$remote_addr $ssl_client_s_dn $ssl_client_verify $remote_user [$time_local] '
'"$request" $status $body_bytes_sent '
'"$http_referer" "$http_user_agent"';
server {
listen 80;
listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
server_name serveurwapt.domain.local;
server_name X.X.X.X;
access_log "/var/log/nginx/access.log" combined_ssl;
ssl_certificate "/opt/wapt/waptserver/ssl/cert.pem";
ssl_certificate_key "/opt/wapt/waptserver/ssl/key.pem";
ssl_dhparam "/etc/ssl/certs/dhparam.pem";
ssl_prefer_server_ciphers on;
ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
ssl_stapling on;
ssl_stapling_verify on;
ssl_session_cache none;
ssl_session_tickets off;
# HSTS (ngx_http_headers_module is required) (63072000 seconds)
add_header Strict-Transport-Security "max-age=63072000" always;
ssl_client_certificate "/opt/wapt/conf/ca-wapt.crt";
ssl_crl "/opt/wapt/conf/ca-check-clients.crl";
ssl_verify_client optional;
gzip_min_length 1000;
gzip_buffers 4 8k;
gzip_http_version 1.0;
gzip_disable "msie6";
gzip_types text/plain text/css application/json;
gzip_vary on;
index index.html;
server_tokens off;
client_max_body_size 12288m;
client_body_timeout 1800;
large_client_header_buffers 4 16k;
proxy_headers_hash_max_size 1024;
proxy_headers_hash_bucket_size 128;
proxy_request_buffering off;
location ^~ /.well-known/acme-challenge/ {
default_type "text/plain";
root /var/www/html;
# sub instances
include "/opt/wapt/conf/wapt.d/*.conf";
location /static/ {
alias "/opt/wapt/waptserver/static/";
location /ssl/ {
alias "/var/www/ssl/";
# not protected URL
location ~ ^/(robots.txt|wapt/waptsetup.*\.exe|wapt/ping|wapt/waptagent/.*|wapt/waptagent\.exe|wapt/waptdeploy\.exe|wa pt/conf\.d/.*\.json)$ {
add_header Cache-Control "store, no-cache, must-revalidate, post-check=0, pre-check=0";
add_header Pragma "no-cache";
root "/var/www";
location ~ ^/api/v3/(wads_register_host|set_host_wads_status|baseipxe|get_host_ipxe|get_wads_exe.*|get_wads_config)$ {
proxy_http_version 1.1;
include "/opt/wapt/conf/forward_ssl_auth.conf";
rewrite /(.*) /$1 break;
proxy_pass http://127.0.0.1:8080;
# not protected URL
location /wads/ {
sendfile on;
sendfile_max_chunk 1m;
tcp_nopush on;
alias "/var/www/wads/";
# homepage
location = / {
# SSL protected URL or cacheable
location /waptwua/ {
sendfile on;
tcp_nopush on;
include "/opt/wapt/conf/require_ssl_auth.conf";
alias "/var/www/waptwua/";
# SSL protected URL but never cached
location ~ ^/(wapt/Packages)$ {
sendfile on;
tcp_nopush on;
root "/var/www";
location ~ ^/(wapt/.*)$ {
sendfile on;
tcp_nopush on;
root "/var/www";
# SSL protected URL but Never cached
location ~ ^/(licences\.json|sync\.json)$ {
sendfile on;
tcp_nopush on;
root "/var/www";
# SSL protected only when wads is not enabled
location /rules.json {
root "/var/www";
# we don't want to expose our list of computers in case someone scan this folder.
location /wapt-host/Packages {
return 403;
# SSL protected and non cacheable
location ~ ^/(wapt-host/.*)$ {
log_not_found off;
root "/var/www";
location ~ ^/.*_kerberos$ {
return 404 "Kerberos is disabled";
# we need socketio for these actions.
# they are enabled only locally on the loopback
location ~ ^/api/v3/(update_hosts_sid_table|hosts_sid)$ {
allow 127.0.0.1;
deny all;
location ~ ^/api/v3/(trigger_host_action|reset_hosts_sid|host_tasks_status|trigger_cancel_task|hosts_delete|launch_syn c_on_remotes_repos|broadcast_sync_on_remotes_repo)$ {
limit_req zone=wsgi burst=20 delay=10;
# old API
location /get_websocket_auth_token {
return 404;
# these actions are not protected by SSL client side certificate, as we perhaps don't have one at this stage.
# in case uwsgi is enabled, we wat this to still be handled by eventlet waptserver as these endpoints are not cpu inte nsive but often called
# don't use uwsgi for this
location ~ ^/(ping)$ {
limit_req zone=wsgi burst=200 delay=100;
# Not protected by SSL client side certificate, as we perhaps don't have one at this stage.
# use uwsgi for this if enabled
location ~ ^/(api/v3/get_temp_client_cert|login|api/v3/login|login_kerberos|api/v3/login_kerberos|api/v3/logout|api/v3 /get_hash_json_content|api/v3/waptagent_version|add_host|api/v3/add_host|add_host_kerberos|api/v3/add_host_kerberos|api/v3 /get_waptagent_exe/.*/waptagent.exe)$ {
limit_req zone=login burst=20 delay=10;
# Big upload endpoints
location ~ ^/api/v3/(upload_deploy_files|upload_packages|upload_file){
client_max_body_size 107520m;
location / {
location /socket.io {
limit_req zone=websockets burst=300 delay=100;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_pass http://127.0.0.1:8080/socket.io;
# configuration file /opt/wapt/conf/forward_ssl_auth.conf:
# default forwarded headers
# to inform agent about its external ip
# works only if there is no other reverse proxy or no nginx in stream mode
# in front of wapt server
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $remote_addr;
proxy_set_header X-Forwarded-Proto $scheme;
# in case ssl auth is not enabled, this set haders to empty strings
# this is important since we trust these headers
proxy_set_header X-Ssl-Authenticated $ssl_client_verify;
proxy_set_header X-Ssl-Client-Dn $ssl_client_s_dn;
proxy_set_header X-Ssl-Client-Sha1 $ssl_client_fingerprint;
# configuration file /opt/wapt/conf/require_ssl_auth.conf:
# require ssl auth and format auth information to proxied server
if ($ssl_client_s_dn = "") {
add_header 'Content-Type' 'text/ascii';
return 401 "Requires ssl auth";
if ($ssl_client_verify = SUCCESS) {
set $auth_ok 1;
add_header X-Remote-IP $remote_addr;
if ($auth_ok != 1) {
return 403 "Bad client authentication"; # $ssl_client_verify
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
Maintainer: Debian Nginx Maintainers <pkg-nginx-maintainers@alioth-lists.debian.net>
Celine
