error launching update-package
Answer
Catherine
Registration: March 26, 2026 - 4:16 PM
June 18, 2026 - 09:52
Good morning, :)
When I try to run the update packages for the Windows 11 upgrade template file, I get this error message:
Windows 11 Update Template version 0-117
When running update-package: error
[WARNING] Errors found in microsoft download link response. (Trying another method)
[ERROR] No download links available after all attempts.
CRITICAL:waptcore:Fatal error in update_package  EWaptSetupException: Fatal error : No download links available:
  File "C:\Program Files (x86)\wapt\common.py", line 9161, in call_python_code
    hookdata = hook_func()
  File "C:\Users\A-CBRO~1\AppData\Local\Temp\wapt\Y9LJG3QT\cb-windows11-upgrade-template_0-117_x64_windows_6.1_PROD-wapt\update_package.py", line 281, in update_package
    error("No download links available")
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2176, in error
waptutils.EWaptSetupException: Fatal error : No download links available
  File "C:\Program Files (x86)\wapt\common.py", line 9165, in call_python_code
    raise e
Can you help me, please?.
Have a lovely day! :D
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
June 18, 2026 - 12:31
Could you please tell me at which step of the update_package() function you are encountering this error?
Ingrid
Catherine
June 19, 2026 - 3:53 PM
Right after selecting French as the language and launching the update-package for the selected packages, there's a progress bar on the right that I've copied.
Regards
June 22, 2026 - 10:41
I just tried it here, it might have been a problem with Microsoft, but everything is working now.
Could you try again?
Catherine
June 22, 2026 - 4:10 PM
thank you very much, it's working now.
Have a lovely day. :D
Catherine
June 23, 2026 - 09:28
Hello, a small correction: when I download version 25H2, it reports the following: ---> -> download finished (16.04Mb/s)
Extracting: Win11_25H2_French_x64.iso
Software version updated from: 0 to: 10.0.26100
Changing package name to: cb-windows11-25H2
Changing locale to: fr in WAPT\control.
I tested the migration on another PC, and it tells me I'm still on 24H2 10.0.26100
and not 25H2 0.0.26200.
Are you experiencing this problem? Have
a nice day! :D
wapt update package.png (43.28 KB) Viewed 10810 times
Answer
