[SOLVED] forticlient-vpn error
stan
Registration: May 26, 2025 - 10:16 p.m.
June 23, 2026 - 3:59 PM
We have a problem with the forticlient-vpn package.
It installs correctly, but still displays an error in the logs.
This is a problem for us, because the forticlient-vpn-config package depends on it, and therefore does not install because FortiClient reports an error.
Here are the logs for the forticlient-vpn installation task:
Installing: FortiClientVPN.msi (7.4.3.8758)
Waiting for key: {15C7B361-A0B2-4E79-93E0-868B5000BA3F} to appear in Windows registry
Removing: FortiClient VPN (7.4.3.8758)
Waiting for the removal of key: {15C7B361-A0B2-4E79-93E0-868B5000BA3F} from Windows registry
INFO: Reboot is required to avoid error 1603 with FortiClient VPN
Erreur lors de l'installation de ['ccpa-forticlient-vpn(=7.4.3.8758-22)']: erreurs dans les paquets [[PackageRequest(package='ccpa-forticlient-vpn',version=(Version('7.4.3.8758'), 22),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD', 'ADMINS'],tags=['windows'],min_os_version=Version('10.0.26200'),max_os_version=Version('10.0.26200')), PackageEntry('ccpa-forticlient-vpn','7.4.3.8758-22' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5723, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4629, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4534, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Program Files (x86)\\wapt\\private\\tmp\\waptfnaw4fij\\setup.py", line 85, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5747, in install\n    raise EWaptInstallError(\'Install errors: %s\' % \',\'.join(str(a[0]) for a in actions[\'errors\']))\nwaptpackage.EWaptInstallError: Install errors: ccpa-forticlient-vpn [x64_fr_PROD,PREPROD,ADMINS],ccpa-forticlient-vpn-config(=0.2-16) [x64_fr_PROD,PREPROD,ADMINS]\n']]
  File "<string>", line 1696, in run
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 891, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1525, in _run
Exception: Erreur lors de l'installation de ['ccpa-forticlient-vpn(=7.4.3.8758-22)']: erreurs dans les paquets [[PackageRequest(package='ccpa-forticlient-vpn',version=(Version('7.4.3.8758'), 22),architectures=['x64'],locales=['fr'],maturities=['PROD', 'PREPROD', 'ADMINS'],tags=['windows'],min_os_version=Version('10.0.26200'),max_os_version=Version('10.0.26200')), PackageEntry('ccpa-forticlient-vpn','7.4.3.8758-22' architecture='x64',maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5723, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4629, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4534, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Program Files (x86)\\wapt\\private\\tmp\\waptfnaw4fij\\setup.py", line 85, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5747, in install\n    raise EWaptInstallError(\'Install errors: %s\' % \',\'.join(str(a[0]) for a in actions[\'errors\']))\nwaptpackage.EWaptInstallError: Install errors: ccpa-forticlient-vpn [x64_fr_PROD,PREPROD,ADMINS],ccpa-forticlient-vpn-config(=0.2-16) [x64_fr_PROD,PREPROD,ADMINS]\n']]
    self._run()
If you can provide any clarification, I would be very grateful! :D
Stan
Information:
Version: WAPT Enterprise 2.6.1.17813
OS Serveur: Debian 12
OS Administration: Windows 25H2
June 24, 2026 - 09:34
Hello
, you're not looking at the error in the right place. You need to go to the general tab and click on the package with the error to see the exact error.
stan
June 24, 2026 - 10:27
That's exactly what I did.
Edit:
My mistake, that's not what I did, I don't know where I found those logs.
Here are the error logs:
  File "C:\Program Files (x86)\wapt\common.py", line 4534, in install_wapt
  File "C:\Program Files (x86)\wapt\private\tmp\waptjgsrpqvc\setup.py", line 70, in install
  File "C:\Program Files (x86)\wapt\common.py", line 4189, in run
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2423, in run
waptutils.CalledProcessErrorOutput: Command ['MsiExec.exe', '/X{15C7B361-A0B2-4E79-93E0-868B5000BA3F}', '/q', '/norestart'] returned non-zero exit status 1603.
Output:
Output:
Stan
Information:
OS Administration : Windows 11 25H2
OS Server : Debian 12
WAPT Version : 2.6.1.17813
VSCode Version : 1.116.0
June 24, 2026 - 10:40
It's error 1603, so very broad.
The package states: INFO: Reboot is required to avoid error 1603 with FortiClient VPN.
Have you restarted?
stan
June 24, 2026 - 10:49
Yes, even several times
Stan
Information:
June 24, 2026 - 10:55
In this case, since it's error 1603 "fatal error during installation",
you need to run the installation manually on the machine to see what it says using the GUI (with the same MSI file as the package).
stan
June 25, 2026 - 09:01
I performed the installation manually with the same MSI as the package, no errors, FortiClient VPN installs correctly. :(
Stan
Information:
June 25, 2026 - 4:31 PM
Hi Stan,
when you performed the manual installation test, was it in administrator mode or in LOCALSYSTEM?
stan
June 25, 2026 - 4:39 PM
I did it in an Administrator context and not LOCALSYSTEM. I will try installing it in LOCALSYSTEM.
Stan
Information:
June 25, 2026 - 5:39 PM
Hello Stan,
To switch to a system account, you can install the tis-sysinternals-pstools package and then perform a
psexec -s -i cmd
There are a number of things that behave slightly differently in the LocalSystem account. Some installers aren't very good at this...
