I don't think this is a serious issue, but when I type a PC's ID number in the search bar and the PC is connected, it doesn't appear. However, if I leave it blank
and search for it in the list of machines, it's visible. Furthermore, the "Edit machine" option is grayed out, as are the "Check for updates" and "Run installations" options.
I've even shut down the console and restarted my virtual machine, but the problem persists.
[SOLVED] PC search
if I don't enter the PC number, I can find it in the console, it's properly connected, and everything is active.
But if I enter it in the search bar, it doesn't see it, and all three options are greyed out.
- Attachments
- PC not visible.png (72.01 KB) Viewed 13290 times
