[SOLVED] Correction for the Phylogène Lycée package (2.7.6.1-3)
jmarcot
Registration: June 29, 2026 - 3:06 PM
June 29, 2026 - 3:20 PM
After attempting to deploy the tis-phylogene-lycee package (version 2.7.6.1-3) on several different workstations, we are encountering difficulties (crash on launch, error message and memory leak then crash) when the shortcuts on the Desktop and Start Menu do not populate the Working Directory ("Start in") with "C:\Program Files (x86)\Phylogène Lycée\Programmes".
These bugs are no longer noticeable when this value is present.
Please find the setup.py file with the fix below:
Thank you in advance for your help
JM
# This file is part of WAPT Enterprise
# All right reserved, (c) Tranquil IT Systems 2024
# For more information please refer to
# https://wapt.tranquil.it/store/licences.html
app_name = "Phylogène Lycée"
app_dir = makepath(programfiles32, app_name)
work_path = makepath(app_dir, "Programmes")
app_path = makepath(work_path, "Phylo.exe")
icon_path = app_path
audit_version = False
def get_installed_version(app_path):
    return get_file_properties(app_path).get("FileVersion", "")
    # Declaring local variables
    zip_name = glob.glob(f"Phylogene-Lycee-2021.zip")[0]
    unzip_dest = "."
    unzipped_dir = "Phylogène-Lycée-2021"
    # Removing old portable app
    old_app_dir = makepath(programfiles32, "Phylogene-lycée")
    if isdir(old_app_dir) and app_dir != old_app_dir:
        remove_tree(old_app_dir)
    unregister_uninstall(app_name)
    # Installing software
    if isdir(app_dir) and force:
        remove_tree(app_dir)
    mkdirs(app_dir)
    print("Extracting: %s to: %s" % (zip_name, app_dir))
    unzip(zip_name, unzip_dest)
    copytree2(unzipped_dir, app_dir, onreplace=default_overwrite)
    # Creating custom shortcuts
    create_desktop_shortcut(app_name, target=app_path, wDir=work_path)
    create_programs_menu_shortcut(app_name, target=app_path, wDir=work_path)
def audit():
    # Auditing software
    audit_status = "OK"
    installed_version = get_installed_version(app_path)
    if Version(installed_version) < Version(control.get_software_version()) and audit_version:
        print("%s is installed in version (%s) instead of (%s)" % (app_name, installed_version, control.get_software_version()))
        audit_status = "WARNING"
    elif isdir(app_dir) and not dir_is_empty(app_dir):
        print("%s (%s) is installed" % (app_name, installed_version))
        audit_status = "OK"
        print("%s is not installed" % app_name)
        audit_status = "ERROR"
    return audit_status
    # Uninstalling software
    if isdir(app_dir):
    # Removing shortcuts
    remove_desktop_shortcut(app_name)
    remove_programs_menu_shortcut(app_name)
kcherel
Registration: January 12, 2026 - 10:01
June 29, 2026 - 4:18 PM
Hi jmarcot,
Thank you so much for your feedback!
I'll look into your suggestion and make the change in the store.
The fact that the "Working Directory" isn't clearly defined can cause this kind of problem.
The new package will be available in production within 5 days.
Have a good day,
Kevin.
