Webex Package
Answer
elchapulin
Registration: June 9, 2023 - 2:47 PM
July 10, 2026 - 4:44 PM
I'm trying to create a package to deploy Cisco Webex on my workstations.
It works in my test environment.
On one machine, I consistently get this error:
installing: Webex.msi
Installing: Webex.msi (44.7.0.30285)
Waiting for key: {3F9B1AB5-2521-521E-8703-87D71A454DD7} to appear in Windows registry
  File "C:\Program Files (x86)\wapt\common.py", line 4510, in install_wapt
  File "C:\WINDOWS\TEMP\wapttcihpwwk\setup.py", line 16, in install
  File "C:\Program Files (x86)\wapt\common.py", line 4427, in new_func
    return func(*args, **kwargs)
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 1666, in install_msi_if_needed
    error('MSI %s has been installed but the %s can not be found' % (msi,searchparam))
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2093, in error
waptutils.EWaptSetupException: Fatal error : MSI Webex.msi has been installed but the key {3F9B1AB5-2521-521E-8703-87D71A454DD7} can not be found
Any ideas? Thank you so much for your help
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
July 10, 2026 - 5:26 PM
According to the error, the expected registry key does not match what is present in the registry.
Once the software is installed, could you run the command: "wapt-get list-registry webex --json" in a command prompt and send us the result?
Is it also possible to view the script in the setup file?
Ingrid
Answer
