Audit problem with a package
Answer
Sami Khelil
Registration: June 19, 2026 - 5:22 PM
August 21, 2026 - 7:35 PM
I recently encountered a problem with a package that returns the following message in the console (version 2.6.1.17.813):
Audit result: XXX-auto-upgrade: error Bad or no control found for XXX-auto-upgrade.
This problem is visible on a few PCs. The message repeats every 1 to 3 seconds, which is annoying. Furthermore, when the PC is shut down, it remains stuck and won't shut down while trying to run this audit.
Sami Khelil
August 21, 2026 - 7:39 PM
I should add that this is a simple package that only creates a scheduled task and copies an executable. I also tried adding the following function to return 'OK':
`def audit():
return 'OK'`.
But it still returns this error message in the console.
Sami Khelil
August 24, 2026 - 5:14 PM
That's weird: if there's a packet error, it's impossible to shut down or restart the PC :O
Answer
