But this doesn't return all versions, only the current one?
The goal would be to retrieve all versions in order to browse through them and delete any that differ from the current one using your last link.
Cleaning old version package
- WAPT Expert
This:
https://github.com/comitari/wapt-packag ... tup.py#L71
returns all packages
. And the local_package_list dictionary returns all the latest versions of packages for each host capability.
Basically, anything that doesn't appear in local_package_list but appears above it should be removed.
Kevin-LH76
- Registration: February 8, 2026 - 5:57 PM
`store_localstore = localstore.packages()` simply returns the latest version of the package from the repository, but how to say..
I'm deleting the different versions
Example: microsoft-defender-antivirus-definition-update is version - 1.457.318.0-320
store_localstore = localstore.packages() returns a line with version 1.457.318.0-320, whereas in the database there are 929 lines for this package.
How can I either delete all the different versions or at least the lists to remove them using `delete package`?
Because in your documentation, package delete requires a specific version
Removes a package of a specific version. The request must be a list []. It can take multiple packages separated by commas, .
Example:
wapt-get server-request /api/v3/packages_delete --method=POST --data="['ht-wapt-debian-gui_2.6.0.16977-2_0fce3ca2b61ebdbdc9b4b065cfe87176_PROD.wapt']" -c /opt/wapt/wapt-get.ini --wapt-server-user=user --wapt-server-passwd=password
