Error installing the PuTTY package
Eglyn
Registration: March 21, 2017 - 2:39 PM
March 21, 2017 - 2:43 PM
Hello everyone,
I get an error when I try to install the PuTTY 0.65 package:
Installation of pkg-putty (=0.65-2) (task #16);Exception: Error during install of pkg-putty (=0.65-2): errors in packages [[u'pkg-putty (=0.65-2)', PackageEntry('pkg-putty','0.65-2')]];2017-03-21T14:23:37.041000;"Installing pkg-putty
Exception: Error during install of pkg-putty (=0.65-2): errors in packages [[u'pkg-putty (=0.65 2)',PackageEntry('pkg-putty','0.65-2')]]
When I look at the processes on the client machine, I see a 32-bit putty/setup process running continuously. I have to kill this process if I want other packages to install.
Does anyone have any ideas?
Thanks in advance :)
March 21, 2017 - 8:42 PM
PuTTY 68 has just been installed as an MSI.
I haven't pushed it to the main tranquil.it repository yet.
You can still test it here:
https://wapt.lesfourmisduweb.org/detail ... 1_all.wapt
Eglyn
March 24, 2017 - 09:31
Okay, thanks. I just saw that the putty 0.68 package is available in the main repository, but it's not updating via wapt-get upgrade (it tells me there are no updates for 0.65-2). Is that normal?
Eglyn
March 24, 2017 - 10:45
Okay, I finally answered my own question, it worked. I restarted my computer, and `wapt-get upgrade` successfully updated everything :)
March 26, 2017 - 3:44 PM
For your information,
an update must precede an upgrade; otherwise, the agent will not know if updates are available.
https://www.wapt.fr/fr/doc/Theorique/index.html#upgrade
An update is performed by default every 120 minutes:
https://www.wapt.fr/fr/doc/Installation ... pt-get-ini
