[RESOLVED] Secondary repositories in HTTPS
Answer
maurped
Registration: January 19, 2026 - 09:10
August 31, 2026 - 10:43
I can't get my secondary repositories to use HTTPS.
When I change the repository URL, the agent can no longer find it.
Screenshot 2026-08-31 104015.png (9.72 KB) Viewed 43115 times
How can I switch my secondary repositories to full HTTPS?.
THANKS
August 31, 2026 - 11:49
Hi Clément,
which CA did the certificates deployed to the secondary repositories come from? Is this CA recognized by the WAPT agent?
Regards,
maurped
August 31, 2026 - 12:08
The repositories contain the certificates of the technicians who have console access in the folder C:\Program Files (x86)\wapt\ssl,
and the certificate of the main server in C:\Program Files (x86)\wapt\ssl\server.
They also have the remote-repo-http package without any special configuration.
maurped
September 2, 2026 - 2:51 PM
Do I need additional certificates?
September 2, 2026 - 3:02 PM
If you want an HTTPS repository, you need a Public Key Infrastructure (PKI
. You must create a certificate issued by a Certificate Authority (CA) (which you already have, such as OpenSSL, ADCS, or another) for your repositories and your WAPT server.
Then, in `verify_cert` (wapt-get.ini), you must specify your CA.
This will enable valid HTTPS validation.
maurped
September 2, 2026 - 3:44 PM
Thank you for the response. An internal PKI is being considered, so we will revisit this at that time.
Answer
