run
Gaelds
Registration: Nov 22, 2015 - 08:37
March 17, 2017 - 09:50
I use the following command in one of my packages
run_notfatal(r'wuauclt.exe /resetauthorization /detectnow')
But I get the following message:
Warning: Command 'wuauclt.exe /resetauthorization /detectnow' returned non-zero exit status 1.
Output: 'wuauclt.exe' is not recognized as an internal or external command, executable program or batch file.
However, I can run this command manually on the machine; I haven't found an explanation in the Wapt documentation...
March 17, 2017 - 9:46 PM
The path to system32 needs to be specified
run( '"%s" /resetauthorization /detectnow' % makepath(system32,'wuauclt.exe') )
Gaelds
March 22, 2017 - 3:44 PM
Sorry, but I'm still getting the following error with this last command:
Warning: Command '"C:\\Windows\\system32\\wuauclt.exe" /resetauthorization /detectnow' returned non-zero exit status 1.
Output: "C:\\Windows\\system32\\wuauclt.exe" is not recognized as an internal or external command, operable program or batch file.
March 22, 2017 - 3:56 PM
Likely a 32-64 bit redirection problem because wapt is 32-bit so Windows makes a "transparent" rewrite of certain paths to show the wapt process a 32-bit type system.
To disable this redirection:
with disable_file_system_redirection():
Gaelds
March 23, 2017 - 11:50
Yes, it works well with the disable_file_system_redirection instruction, thank you!
