[SOLVED] PC search
Catherine
Registration: March 26, 2026 - 4:16 PM
September 21, 2026 - 3:33 PM
I would like to know if I can search for multiple PCs at the same time. In other words, I would like to see the PCs I've asked to be found,
i.e.,
in the search: I would like x, yy, syz, abc, zds, ... and have them displayed.
I can only search one at a time.
Awaiting your reply, I wish you a nice day.
blemoigne
Registration: July 17, 2020 - 11:29
September 22, 2026 - 11:07
Hello Catherine,
You can separate the machines with a pipe | in the machine search bar: machine1|machine2|machine3
It is also possible to filter machines according to an SQL query defined in the reporting tab: https://www.wapt.fr/fr/doc/wapt-console ... entory-tab
You can also select multiple machines and then filter the machines on which a particular package is installed in the "Package Status Summary" tab by clicking on the number of machines with the package:
Screenshot 2026-09-22 110616.png (196.68 KB) Viewed 10232 times
Good day,
Bertrand
