[SOLVED] tis-jabra-direct - windows
b.ald
Registration: Oct 04, 2025 - 10:59 p.m.
September 25, 2026 - 4:33 PM
The package update resulted in an error.
The "_file" is missing after "remove" when deleting the old binary (l.23).
    for f in glob.glob('*.exe'):
        if get_file_properties(f)['ProductVersion'] != Version(windows_version):
            remove(f)
Regards,
Bastien
WAPT Enterprise -- 2.6.1.17870 -- SRV Ubuntu 24.04 arm64
WAPT Enterprise -- 2.6.1.17813 -- SRV Ubuntu 22.04
WAPT Enterprise -- 2.6.1.17813 -- SRV RHEL 9 --//-- Secondary Repositories -- Rocky 9/10
Admin: W11pro
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
September 25, 2026 - 4:39 PM
Noted, we will look into it. Thank you.
Best regards,
Ingrid
italbot
September 28, 2026 - 09:52
I just made the change but there's an error during installation. I'll look into it.
Regards,
Ingrid
kcherel
Registration: January 12, 2026 - 10:01
October 19, 2026 - 4:47 PM
Thank you for your feedback. The new Jabra Direct version will be available in its latest version within 5 days, but you can download the pre-production version now: https://wapt.tranquil.it/store/fr/wapt- ... EPROD.wapt
Kevin.
