Error creating package
avondra
Registration: Nov 9, 2016 - 12:02
March 31, 2017 - 6:35 PM
I'm using PyScripter and when creating a new package, I consistently get this error:
Command Line: -ldebug install C:\Program Files (x86)\wapt\waptdev\tis-interactivesoftphone-64-wapt\WAPT
installing WAPT packages C:\Program,Files,(x86)\wapt\waptdev\tis-interactivesoftphone-64-wapt\WAPT
FATAL ERROR: AttributeError: 'NoneType' object has no attribute 'groupdict'
File "c:\Program Files (x86)\wapt\wapt-get.py", line 1145, in
main()
File "c:\Program Files (x86)\wapt\wapt-get.py", line 389, in main
usecache = not (action == 'download' and options.force)
File "c:\Program Files (x86)\wapt\common.py", line 3960, in install
actions = self.check_depends(apackages,force=force or download_only,forceupgrade=True)
File "c:\Program Files (x86)\wapt\common.py", line 3773, in check_depends
old_matches = self.waptdb.installed_matching(request)
File "c:\Program Files (x86)\wapt\common.py", line 1715, in installed_matching
package = REGEX_PACKAGE_CONDITION.match(package_cond).groupdict()['package']
AttributeError: 'NoneType' object has no attribute 'groupdict'.
Do you have any suggestions for resolving this?
Thank you in advance.
April 3, 2017 - 10:18
I suspect a problem with the Wapt installation path containing spaces, which may be mishandled in the Pyscripter project commands.
To correct:
Right-click on the "install" item in the "Run configurations"
Select Edit execution configuration
In the Settings area, replace
-ldebug install $[ActiveDoc-Dir]
by
-ldebug install "$[ActiveDoc-Dir]"
PS:
The path to the waptdev directory might be incorrect... It seems to be a subdirectory of the directory where the wapt agent itself is installed. It would be better if it were outside of that directory.
avondra
April 3, 2017 - 12:54
thank you for your reply. I think we're on the right track, because my Wapt installation is in Program Files (x86)\. I modified the line and now I have the following response in the console. Is this normal?
Command Line: -ldebug install c:\Program Files (x86)\wapt
I also modified the parameter in -i build upload, but I don't get any login/password prompt, the upload doesn't complete, and I get a similar message:
Command Line: -ldebug -i build-upload "c:\Program Files (x86)\wapt"
What do you think?
avondra
April 3, 2017 - 6:19 PM
By "playing" with the quotation marks, I now arrive at a different error:
2017-04-03 18_15_05-PyScripter - c__Program Files (x86)_wapt_common.py.png (18.21 KB) Viewed 7315 times
April 4, 2017 - 9:48 AM
if I search for the error code 1625 for an MSI file (
https://msdn.microsoft.com/en-us/librar ... 85%29.aspx),
Microsoft indicates: "
This installation is forbidden by system policy. Contact your system administrator."
Simon Fonteneau
