uninstall and uninstallstring
Stenon
Registration: June 2, 2016 - 8:04 AM
September 28, 2016 - 1:11 PM
Hi,
here's my setup.py code.
It's a batch file for installation and it works fine. I'm also trying to run an uninstallation with a batch file, and it's crashing...
which should I use, uninstall or uninstallstring? Thanks for your help!
uninstallstring = [u'"C:\\FirewallRemoveEsetRule.bat"']
run(r'"FirewallAddEsetRule.bat"')
run(u'"FirewallRemoveEsetRule.bat"')
and errors:
2016-09-28 15:09:00,963 WARNING Warning: CalledProcessError: Command '(u'"C:\\FirewallRemoveEsetRule.bat"',)' returned non-zero exit status 1
2016-09-28 15:09:00,986 CRITICAL Error running uninstall script: Command '(u'"FirewallRemoveEsetRule.bat"',)' returned non-zero exit status 1
=== Removed packages ===
allowesetinstall
=== Error removing packages ===
allowesetinstall
Nathanael
Registration: August 18, 2016 - 5:16 PM
April 10, 2017 - 4:32 PM
have you found a solution to this question since then?
Nathanael
agauvrit
Registration: Nov 17, 2016 - 10:25
April 10, 2017 - 4:58 PM
Stenon wrote:
During installation, your *.bat script runs correctly, no problem, since it's included in your package (I assume?)
The uninstall, however, fails because at no point in the install function do you copy and paste this script to the root of the C:\ drive
If you want this to work, use a file copy with the function filecopytowhich will allow you to call your script FirewallRemoveEsetRule.bat during uninstallation.
The source code would then become:
    filecopyto("FirewallRemoveEsetRule.bat","C:\\")
    run(u'"C:\\FirewallRemoveEsetRule.bat"')
Alexander
Stenon
April 22, 2017 - 12:55
Thanks,
in the meantime I had created a second wapt package that called remove.bat.
But a big THANK YOU for your explanation and your clear answer!
PS: The livecast video was very, very good; we seem to know you better now.
