activation delayed
Stenon
Registration: June 2, 2016 - 8:04 AM
May 2, 2017 - 1:14 PM
Hi,
Can you help me write the following code using environment variables?
The following script works well; it covers 32-bit and 64-bit Windows and 32-bit and 64-bit Office, but is there a simpler, more advanced way? Thanks
target = "C:\Program Files (x86)\Microsoft Office\Office16\OSPP.VBS"
    if os.path.isfile(target):
        print("found file: ospp.vbs - Office 32Bits on a windows 64Bits")
        acto = run(r'C:\Windows\System32\cscript.exe "C:\Program Files (x86)\Microsoft Office\Office16\OSPP.VBS" /dstatus')
        if 'ERROR' in acto :
           print('Activation Status error')
           run(r'C:\Windows\System32\cscript.exe "C:\Program Files (x86)\Microsoft Office\Office16\OSPP.VBS" /inpkey:XXXXX-XXXXX-XXXXX-XXXXX-XXXXX')
           print('Installation Office 2016 key')
           run(r'C:\Windows\System32\cscript.exe "C:\Program Files (x86)\Microsoft Office\Office16\OSPP.VBS" /act')
           print('Already activitate')
            print('Still Activation Status error')
            print('Activation Status OK !!!')
        target = "C:\Program Files\Microsoft Office\Office16\OSPP.VBS"
            print("found file: ospp.vbs")
            acto = run(r'C:\Windows\System32\cscript.exe "C:\Program Files\Microsoft Office\Office16\OSPP.VBS" /dstatus')
               run(r'C:\Windows\System32\cscript.exe "C:\Program Files\Microsoft Office\Office16\OSPP.VBS" /inpkey:XXXXX-XXXXX-XXXXX-XXXXX-XXXXX')
               run(r'C:\Windows\System32\cscript.exe "C:\Program Files\Microsoft Office\Office16\OSPP.VBS" /act')
            print("No Office installed")
agauvrit
Registration: Nov 17, 2016 - 10:25
May 2, 2017 - 3:08 PM
Two areas for improvement:
May 2, 2017 - 3:43 PM
You can also use variables: programfiles
https://www.wapt.fr/fr/doc/CreationPaqu ... -recursion
You can generate an error with:
error('Still Activation Status error')
rather than using a print statement.
