exe autoIt3 and WAPT
Freesco
Registration: June 22, 2015 - 2:52 PM
June 22, 2015 - 3:02 PM
I'm new to software deployment, packaging, etc., and to create applications with specific installation requirements, I wanted to use AutoIt to automate my installations before deploying them via WAPT.
Having created several .exe files to automate my application installations, I've reached the point where I'd like to create my packages using WAPT.
Unfortunately, despite my attempts, my installations aren't working.
Has anyone else encountered this situation? Is this the best solution? Does WAPT offer similar capabilities to AutoIt for automating installations during deployments?
Yann
July 16, 2015 - 1:44 PM
I have the same issue.
From what I understand:
Just like pdq deploy or wpkg, wapt uses a system session.
AutoIt3 can therefore work, but not for keyboard or mouse emulation.
However, when the command line is run with an administrator account, wapt-get install smp-test will work.
Mathieu
Registration: August 18, 2016 - 10:24
May 16, 2017 - 4:03 PM
I'd like to know if anyone has successfully used AutoIt3 with its answer file in a WAPT package?
I have no choice but to use this method for installing the software.
When editing in Pscrypter with the installer, everything works, but once it's built and launched via the console, nothing happens with AutoIt.
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
