Uninstalling an old version of Java
Dylan
Registration: June 9, 2016 - 10:28
June 12, 2017 - 11:50
It doesn't seem complicated, and with Simon's help I was able to uninstall older versions of Thunderbird.
I'm using WAPT-fixup with these lines of code
    prefixpkg = control.package.split('-',1)[0]
    java8 = WAPT.is_installed('%s-java8'% prefixpkg)
    if java8 and Version(java8.version) == Version('8.121-24'):
        WAPT.remove(java8.package)
        WAPT.install('%s-java8'% prefixpkg)
My goal is to uninstall only version 8.121. When I run the debugger, I get a NameError: global name 'Version' in not defined. I conclude that, as far as it's concerned, the version is not defined.
Any idea what the problem is?
agauvrit
Registration: Nov 17, 2016 - 10:25
June 12, 2017 - 3:26 PM
The class Version which is used to compare software version numbers has recently moved to a different file in WAPT, during execution there are no problems, but during debugging it gets stuck.
Which version of the agent are you using?
The version class is now located in the waptutils file (C:\wapt\waptutils.py)
Try importing the library like this:
from waptutils import *
Dylan
June 12, 2017 - 4:46 PM
Thank you for the reply.
The agent and console are in version 1.3.12.13.
No, unfortunately, it's not just the debugging that's stuck; the uninstallation doesn't work either.
I don't know where I should insert this line of code
Is it in the setup.py file?
For your information, I don't have a C:\WAPT\waptutils.py file, but I do have a C:\WAPT\waptdevutils.py file, and it contains quite a bit of information. I'm trying to modify the file and adding the following line of code:
Update: Well, it was a bad idea to try and mess with C:\WAPT\waptdevutils.py, so I put it back to how it was originally.
I'm no further ahead; I still can't uninstall the old versions of Java 8.121 :roll:
June 21, 2017 - 00:26
Sorry, I'm really struggling to resolve the issue.
Could you try version 1.3.12.15?
