System error OS Code 2 during server installation
mickael.lombard
Registration: June 16, 2017 - 10:01
June 16, 2017 - 10:06
I am encountering a problem during installation on a Windows 2016 server.
During the WAPT server configuration, I get the following error: "Error during post-config, System error (OS Code 2)":
I repeated the operation on 2 different servers and I get the same error message.
Do you have any idea?
Thank you in advance.
Sincerely
agauvrit
Registration: Nov 17, 2016 - 10:25
June 16, 2017 - 10:38
We recommend installing your WAPT server on a Linux Debian/CentOS platform preferably.
For the server installation on Windows, your error seems to be related to the WAPT service failing to restart. Try using the command line:
net stop WAPTserver
net start WAPTServer
The various services installed under Windows for the WAPT server are:
  • WAPTMongodb
  • WAPTServer
  • WAPTAPache
  • WAPTService
Is there an IIS server on the same machine?
Alexander
mickael.lombard
June 16, 2017 - 11:25
Hello and thank you for your reply.
I think my problem stems from that.
When I try to stop the service, this is what I get:
net stop WAPTserver
The service name is not valid.
You will get more help by entering NET HELPMSG 2185.
June 17, 2017 - 11:20
Hello
, yes, the problem is related to version 1.3.12.14
. We're looking into it. In the meantime, you can stay on version 1.3.12.13.
Or you can switch to the Linux version...
