After reinstalling WAPT, I realized I was using two private keys (likely due to an initial test installation).
I then followed the instructions in the documentation at https://www.wapt.fr/fr/doc/Frequent-problem/index.html in the "Private Key Renewal Procedure " section .
When I run the command `wapt-get sign-packages *` on my administration workstation, I get the following error: "Unknown action sign-packages".
Furthermore, how can I change the signature of my package groups?
Thank you in advance.
Sincerely
Private key problem
mickael.lombard
- Registration: June 16, 2017 - 10:01
I found it simpler to start from scratch.
