Among the packages offered by TIS there is a package that allows you to install an ad blocker in Firefox.
After reading the package I see that there is an "install" function and a "session_setup" function.
extension_directory=os.path.join(programfiles32,'thunderbird-extension','ublock')
if not os.path.exists(extension_directory):
os.makedirs(extension_directory)
copytree2('mozprofile',os.path.join(extension_directory,'mozprofile'))
copytree2('manifestparser',os.path.join(extension_directory,'manifestparser'))
def session_setup():
sys.path.append(extension_directory)
from mozprofile import FirefoxProfile
from mozprofile import addons
from mozprofile import profile
When the "wapt-get" command is called, does the argument passed to it correspond to one of the functions present in the package?
Let's admit
wapt-get install tis-paquet1Therefore, to use the "session_setup" function, you need to run:
wapt-get session-setup tis-paquet1
Is there no implicit default call that launches session-setup if the function exists in the package?
A kind of "install -> If session_setup is defined then session_setup else next"?
Because if that's the case, it means that to install this kind of package you absolutely have to run both commands rather than putting it as a dependency on a package and letting the installation happen automatically?
Thank you for your answers
