The PC shuts down before the scripts finish
Root
Registration: August 2, 2017 - 2:05 PM
August 2, 2017 - 2:23 PM
I use a Python script to launch other scripts (often batch or ps1 files).
In my package, setup.py ends with the instruction:
os.system("cd C:\dossier0\dossier1 && start setup.bat")
In my bat I launch commands wmic (uninstall) and I use other functions which may take some time to complete.
My question is: How can I prevent Wapt from shutting down the computer before the batch process is complete? How can I make Wapt understand that the job isn't finished and that it needs to wait before shutting down?
I thought about using `time.sleep(10)`... but well, it's not very... clean :ugeek: Furthermore, the script does not take the same amount of time on each machine.
By the way:
I discovered WAPT during my studies while looking for deployment software; I use it on my personal computer and, since this year, in the company where I work! It's an excellent product.
I would also like to know where I can report problems related to my packages or my usage.
EDIT: Oops, wrong forum
agauvrit
Registration: Nov 17, 2016 - 10:25
August 2, 2017 - 5:20 PM
Topic moved.
Regarding your question: https://www.wapt.fr/fr/doc/Frequent-pro ... tput-600-0
For your function, you could write it like this:
os.chdir(r"C:\dossier0\dossier1")
run("setup.bat",timeout=1200)
Good package development!
Root
August 3, 2017 - 09:13
agauvrit wrote: August 2, 2017 - 5:20 PM Topic moved.
Thanks for the reply. I'll try your solution in the next update of my package.
I'm considering abandoning batch processing and rewriting my script in Python, but I'm afraid I'll encounter the same problem if I end my Python script with:
os.popen('wmic product where name="SoftwareName" call uninstall')
Good day
swbsf
Registration: July 27, 2017 - 09:50
August 4, 2017 - 10:25
Hi,
I use it successfully:
        cmd="c:\\Windows\\System32\\WindowsPowershell\\v1.0\\powershell.exe -NoProfile -NonInteractive -ExecutionPolicy Bypass -File c:\\tmp\\Win10.ps1"
        proc = subprocess.Popen(cmd,shell=True,stdout=subprocess.PIPE)
        proc.wait()
The `proc.wait()` function works well in my case, as it also reboots the machine at the end of the process. You must, of course, import `subprocess`. And replace `cmd` with your command, whatever it may be.
The timeout=xxx solution is flawed; it's ideal for.. race condition.
Root
August 10, 2017 - 11:43
swbsf wrote: August 4, 2017 - 10:25 Hi,
        proc.wait()
Thanks, I tried it with proc.wait() and it works fine
