I'm using a Windows machine with console version 1.3.12.15. It was working perfectly, but since a server reboot, I can no longer connect to the WAPT server.
I get the following error: HTTP/1.1 404 Not Found.
I've checked the address, tried manually modifying the URLs, rechecked everything, etc., but nothing works; I still get the same error.
The console is installed on the same machine as the server, and nothing has been changed on the server except for the addition of the remote desktop functionality.
connection error: HTTP/1.1
- WAPT Expert
has another service been recently hosted on the machine?
What is the status of the WAPT services? ---> Apache, WaptServer, MondoDB?
Otherwise, you can directly update your WAPT server to version 1.3.13.
